Order Ford 2000 Parts Online
730 Loader on 2000 Help!!
Al
10-19-1999 08:31:29
I have a 2000 that has a 19-528 loader, which everyone tells me is a model 730. The lower arm that supports the bucket needs a replacement pin at the bucket. In the manual it calls for a 1" X 6" pin, but when I pulled the old pin it turned out to be larger than 1" in diam. The local dealers are at a loss, other than the book shows sleeves in each side of the arm that I do not have. This loader has a boss on each side of the larger size. Any ideas???
Jerry
10-19-1999 18:00:10
 Re: 730 Loader on 2000 Help!! in reply to Al, 10-19-1999 08:31:29
Why not just go to a welding shop and have them make you one from cold rolled steel rod?
Dave Mischler
10-19-1999 12:17:33
My question would be, "What size is it?"
If it is the size of a common hitch, draw, or top link pin then only slight modifications should be required.
Al
10-21-1999 06:41:57
 Re: Re: 730 Loader on 2000 Help!! in reply to Dave Mischler, 10-19-1999 12:17:33
Thanks for the suggestions. The pin size is very close to 1 1/8". The normal being 1". I guess I could have someone turn new bushings and pin to fit the current size. Somewhere along the way someone must have had problems and oversized the pin(s).
