Ford 2910 Tractor
Bruce
11-04-1999 10:27:31
Can Anyone give me some info on a FORD Model 2910
Tractor. Reliability etc. Thanks Bruce
Bern
11-04-1999 17:46:47
 Re: Ford 2910 Tractor in reply to Bruce, 11-04-1999 10:27:31
Lousy front axle and steering (2WD). Otherwise, not a bad rig.
Ray Harris
05-15-2005 16:21:53
 Re: Re: Ford 2910 Tractor in reply to Bern, 11-04-1999 17:46:47
I have lost my RPM's and hour meter. I put my positive wire on my battery and didn't have it tight enought. When I started my tractor, the RPM meter stopped working. Do you know where the signal is coming from? I haven't checked the fuse box. Please help.
Bruce
11-05-1999 07:42:34
What's wrong with the front axle. Is it light?
Bruce
RickB.
11-05-1999 14:59:17
 Re: Re: Re: Ford 2910 Tractor in reply to Bruce, 11-05-1999 07:42:34
It's too light for all but the easiest duty. Too many pivot points in the steering linkage, and too many of these are non-regreasable. The steering system relies totally on the steering box to maintain toe, as there is no common tierod. Manual steering is hard, and power steering is assist only, and prone to leaking everywhere except maybe the pump. Just a modern-day version of the 600. (or an 8N with P/S).
Bern
11-05-1999 17:32:45
 Re: Re: Re: Re: Ford 2910 Tractor in reply to RickB., 11-05-1999 14:59:17
Couldn't have said it better myself Rick. Agree 100%.
What did you ever come up with on that 1210 crank pulley? Still curious.
Bruce
11-05-1999 15:08:27
Did they come with live PTO and hydraulics? Thanks for all your inputs. Bruce
RickB.
11-05-1999 17:28:44
 Re: Re: Re: Re: Re: Ford 2910 Tractor in reply to Bruce, 11-05-1999 15:08:27
Yes, it will have live hyd. Pto can be transmission-driven (non-live), live (with 2-stage clutch), or possibly independent if it happens to be a series II tractor. Series II will also have inboard wet brakes, a plus.
curt
11-07-1999 14:32:25
 Re: Re: Re: Re: Re: Re: Ford 2910 Tractor in reply to RickB., 11-05-1999 17:28:44
all 2910s have wet disc brakes all have independent pto these are agood tractor and unless your planning to install a loader the steering will not be a problem the only problem we ever had with a 2910 is its weak in horsepower for the weight of the tractor
