Order Ford 2000 Parts Online
FORD 2000
BOB LAFRAMBOISE
11-05-1999 12:05:58
BT FORD 2000 BLT 1970 3 WKS AGO AND WOULD LIKE TO SHARE INFORMTN W/ANYONE THAT HAS THE SAME TRACTOR. HAS 3PNT AND PTO AND 3 CYC GAS ENGINE. TRACTOR IN TRINIDAD COLO AND BOB UP IN DENVER SO TRACTOR DRIVES LIMITED TO ONCE A MONTH WHEN WE GET DOWN TO OUR 35 ACRES RAW LAND AND 2 RM CABIN LOCATED 200 MILES SOUTH OF DENVER. ANYONE CARE TO RESPOND AS IM SEARCHING FOR DATA ON THIS TRACTOR AND MNTCE PROCEDURES
Jerry (Mo)
11-07-1999 18:26:50
 Re: FORD 2000 in reply to BOB LAFRAMBOISE, 11-05-1999 12:05:58
If your tractor is actually obtaining speeds anything like you indicate, it has a Sherman overdrive in it. The shift lever is on the left side if the bell housing if it does. Shift it out of overdrive to slow it down if it has this auxiliary transmission in it.
Roger
11-06-1999 08:48:09
BOB,
If your 2000 is a 6 or 8 speeds, it is a very good tractor, perhaps : "le meilleur en ville". You can have all info you need from your local New-Holland dealer, Implement & Tractor manuals and those from this site.
Welcome to the forum
Roger
BOB LAFRAMBOISE
11-06-1999 10:43:38
 Re: Re: FORD 2000 in reply to Roger, 11-06-1999 08:48:09
HI ROGER....THKS FOR RESPONDING. MY 2000 IS A 4 SPEED AND SO FAR IVE GIVEN IT LITTLE USAGE DUE TO THE COMMUTE INVOLVED. WAS WONDERING..IS THE 2000 NORMALLY A HIGH SPEED TRACTOR AS 1ST SEEMS GOOD FORUP TO 10MPH BUT 2ND SCOOTS ME UP TO 25 OR SO. SINCE I HAVE SOME ROAD/ROCK WORK TO DO WOULD LIKE THE SPEED REDUCED SO NO DMGE TO MY BK BLADE OR SLIPPING THE CLUTCH ETC. WE MIGHT SNEAK DOWN TO TRINI NEXT WEEK ASSUMING THE SNOW STAYS IN THE SKY AND DOESNT FALL ON MY HEAD.
paul
11-07-1999 22:09:21
 Re: Re: Re: FORD 2000 in reply to BOB LAFRAMBOISE, 11-06-1999 10:43:38
They don't go over 30 mph in high gear, so you've got something not right here. Either the Sherman deal, or you have an 8 speed & are in high range.
--->Paul
Don
11-06-1999 08:28:05
I have the same tractor. It is a great machine and I couldn't keep house without it. Ord3r manuals through this site.
BOB LAFRAMBOISE
11-06-1999 10:51:53
 Re: Re: FORD 2000 in reply to Don, 11-06-1999 08:28:05
HI DON...AND THKS FOR RESPONDING. WENT TO SEE THE NEW HOLLAND DEALER IN PARKER COLO AND HE SUGGESTED I ORDER THE 3 BOOKS THRU AN 800 NUMBR. YESTERDAY I DID JUST THAT AND APPARENTLY THE OPER AND SERV MANUAL WILL BE COMING IN A FEW WEEKS. I ALSO OWN A 1949 AC MODEL D RD GRADER W A SIX CYL FORD ENGINE INSTALLED AFTER SOME WELDING WAS DONE TO ENLARGE THE FRAME A BIT. IT HAS HYDRALICS TO RAISE THE BLADE BUT A MANAUL PIN TURRENT TO SPIN THE BLADE...SURE LIKE IT
