Order Ford 4610 Parts Online
4610 Ford brakes
David
11-19-1999 10:15:34
I have a 4610 Ford which has wet brakes on it. Recentley when the brakes are applied a rubbing noise is herd. The brakes still work fine. Are the brakes wore out, or is something else going on? I would like some advice before I take the axles off. Any help would be appreciated.
Bern
11-19-1999 10:22:47
 Re: 4610 Ford brakes in reply to David, 11-19-1999 10:15:34
If you still have plenty of adjustment left on the adjuster threads, and the brakes don't drag, they are fine, don't take the thing apart. The noise you hear is probably a squall/chatter caused by certain types of oil. If you feel this is the case, go to your local NH dealer and ask for anti-chatter additive part #251403. Make sure you also change the oil at the same time as you put this stuff in, preferably with the NH 134 hydraulic oil.
herve
11-19-1999 12:43:21
 Re: Re: 4610 Ford brakes in reply to Bern, 11-19-1999 10:22:47
Bern is all right. He does mechanics in all the word. He explains me many things on Ford models. Why French dealers are not so good as him?
Can I have this additive in France. I have the same problems on my old 7400
I used a 4610 Mustang for 4500 Hours, no problems on brake because we use the recommanded oil. Be careful also with the gear box I think especially the synchros
Bern
11-19-1999 23:44:27
 Re: Re: Re: 4610 Ford brakes in reply to herve, 11-19-1999 12:43:21
Hey thanks there Herve for the compliment! Your check is in the mail! :-)
