Order Ford 2000 Parts Online
Ford 2000 and 5000; hyd fluid vs. trans fluid
Abe
11-29-1999 14:01:45
On the Ford 2000 and 5000 models is the transmission fluid the same as the hydraulic fluid or are there two seperate units? I would like to change the fluids. What do I need?
JHEnt
12-02-1999 16:17:08
 Re: Ford 2000 and 5000; hyd fluid vs. trans fluid in reply to Abe, 11-29-1999 14:01:45
They both use Ford/NH 134 hyd oil or equivlant. This is for manual trans. The select-o-speed if you have it may be a different oil.
rwells
12-01-1999 05:02:58
Yes,they are the same.Also the power steering & gear box fluid.Most tractor & auto supply stores have it.Ford M-2C53-A Select-0-Speed transmission M-2C41-A Robert
