Order Ford 9N Parts Online
1948-49 9N lift problems
Joe
11-30-1999 09:38:04
I called about a 1948-49 9N that is for sale, person said the 3 pt. raises slow, doesnt matter if it is winter or summer. he put a heavy blade on it and it wouldnt lift it, it does a lighter blade, could there be any major problems with this, thank you Joe
Matt Doyle
11-30-1999 21:30:11
 Re: 1948-49 9N lift problems in reply to Joe, 11-30-1999 09:38:04
Joe, if it's a '48 or '49, it's an 8N not a 9N. As far as major problems is concerned, probably not. The hydraulics on these are not real complicated. It could be any of several things, most likley dirty oil or bad rings in the cylinder or both, or an internal leak in the pump. First step would be to change the hydraulic/transmission/differential oil. They are all one reservoir. After that , if the problem is still there, remove the round plate on the right side of the housing (just in front of the axle) and try to lift the heavy blade. If you see oil dripping down from the top, it's probably the rings in the cylinder. The procedure for changing them is too complicated to describe here. You can email me for that. Also the guys on the N board (link at the top of this page) can help. Most of them are much more knowledgeable than I. Hope this helps
