1973-74 ? Ford Tractor-trying to replace seal on PTO and need help
robin decker
12-05-1999 17:47:23
What are the steps involved in replacing the seal on PTO shaft-my husbands father told him that the outer piece should come off with the shaft coming out. Please help. Or send me in the direction I need to go.
Bern
12-05-1999 19:07:18
 Re: 1973-74 ? Ford Tractor-trying to replace seal on PTO and need help in reply to robin decker, 12-05-1999 17:47:23
It would really help to know what model tractor it is you're working on here.
Robin Decker
12-05-1999 19:52:26
 Re: Re: 1973-74 ? Ford Tractor-trying to replace seal on PTO and need help in reply to Bern, 12-05-1999 19:07:18
I thought I posted a followup with the model.
anyways it is a 3000. thanks in advance.
robin
Bern
12-05-1999 20:45:01
 Re: Re: Re: 1973-74 ? Ford Tractor-trying to replace seal on PTO and need help in reply to Robin Decker, 12-05-1999 19:52:26
Drain the oil in the rear axle. Remove the 4 bolts holding the rear PTO retainer to the axle and remove the retainer and shaft as an assembly. Then pop out the snap ring from the inside of the retainer so you can extract the shaft and then replace the seal.
