1720 temp gauge
Russ
12-18-1999 20:33:36
I`ve got an `88 1720 and the temp gauge quit working. Talked to the Ford dealer and about all they would tell me is that they`ve never seen one fail before, but a new gauge is only $79.99. Before I lay down that much hard earned cash, for a gauge which might not even be bad, does anyone have any ideas? Not long ago, the air filter light starts flashing sporadically, and I put in a new element since the old one had quite a few hours on it. Light still flashes. Could these two problems be related? Everything under the hood looks o.k., and no visible obstructions to the breather. Thanks for any input.
RickB.
12-19-1999 04:49:28
 Re: 1720 temp gauge in reply to Russ, 12-18-1999 20:33:36
I have only seen 1 temp gauge failure on 20 series compacts, and the dealer I work for has hundreds of them out. I would check ALL of the instrument wiring for opens & shorts, and poor grounds, as I believe your problems are related. Look for varmint damage in the harness behind the dash/on top of the fuel tank. Check the gauge by removing the wire from the sender & grounding it to the chassis, it should go to hot. Use a jumper wire also to eliminate the sender wire from the circuit. Good luck.
Russ
12-20-1999 08:27:36
 Re: Re: 1720 temp gauge in reply to RickB., 12-19-1999 04:49:28
RickB., thanks for the advice, sounds like good info to me. For some odd reason,I guess I have considered my tractor immune to rodent damage. Going to head out and check right now. BTW, with almost 1400hrs on mine, this is the first problem I have had. I was beginning to think that it was the perfect machine.
