1620 Ford
Ralph
12-29-1999 16:30:34
Does anyone have experience with a 1620 hydro with front wheel drive? I have been told this one is in the early 1990s with loader and 500 hrs what would the value be? The tractor is clean and straight. Are there any problem areas to look for. Thanks Ralph
RickB.
12-30-1999 14:30:10
 Re: 1620 Ford in reply to Ralph, 12-29-1999 16:30:34
They are good little tractors. Not much specific to look for I can think of. Check for clean hyd oil & recent filters (hydraulic & hydro use the same oil supply but 2 filters). Front axle hub & spindle seals can leak on any NH compact, but it is not an expensive fix. Make sure the glowplug indicator on the dash works, the time delay relay that controls the lamp is short-lived, this does not directly control the glowplugs, just tells when to crank the engine. White grille & side screens indicate an older unit, black would be newer, as 3 or 4 years old max. I don't advise on price here, Post your general location, someone else may help out. I wouldn't be afraid of one as you describe, if I needed one.
Ralph
12-30-1999 16:04:48
 Re: Re: 1620 Ford in reply to RickB., 12-30-1999 14:30:10
Thanks Rick for the info. We live in NE SD
