Bern
Big Johnson
01-08-2000 18:05:28
Went out and cleaned the area real good with wire brush and the numbers are J276 located just behind starter on top of transmission housing.
Bern
01-08-2000 19:39:36
 Re: Bern in reply to Big Johnson, 01-08-2000 18:05:28
Then I honestly don't know what you have. Best to send me a picture of it, or else describe it as best you can (# of engine cylinders, transmission type etc.), with any other numbers, etc. you can find on that tractor.
Big Johnson
01-09-2000 08:14:13
 Re: Re: Bern in reply to Bern, 01-08-2000 19:39:36
Here is the engine serial # NDO579O4J136
I also found this number were Hydraulic production code is located # 875 14
Bern
01-09-2000 09:07:29
 Re: Re: Re: Bern in reply to Big Johnson, 01-09-2000 08:14:13
Wow, now I'm confused all the more. I have never seen any numbers like that before. Could be something that was mfg'd down under or some such place.
Any way you can get a picture of it to me?
