Order Ford 861 Parts Online
Ford 861 vs. Oliver Super 55/550
Bob Kirk
01-12-2000 07:32:22
I have been looking for a utility tractor with low center of gravity for woods work, snow plowing, family gardening, mowing, etc. I had been focusing on an Oliver Super 55 or 550 as a useful package -- live hyd + pto, tough, fixable -- for not too much money.
But I ran across a Ford 861, which apparently came with lots of standard features, including live hyd + pto.
Can you all suggest particular weaknesses I should look for in this tractor? (I'm told its had a recent engine rebuild.) What's a "Rest-O-Ride" seat???
Have any of you had experience both with the 861 and an Oliver 55/550 and have a judgment about how they compare?
Thanks very much for your help.
Bob Kirk
Bill Cooman
01-15-2000 13:36:33
 Re: Ford 861 vs. Oliver Super 55/550 in reply to Bob Kirk, 01-12-2000 07:32:22
Bob, We had a Ford 841 Powermaster w/ industrial loader when I was growing up. Not a bad machine, but a couple of flaws that come to mind are: (1) Front axle/spindles was too light for that loader (I can remember snapping at least two spindles and cracking the axle once); (2) Not enough gearing choices (ours had a 4x1 tranny); (3) Six volt system not adequate power for that engine (we were constantly replacing battery probably every two years); (4) With the loader on, it was a little light in the rear despite loaded tires and wheel weights. Admittedly, we may have been asking it to perform tasks which it wasn't quite designed or intended to do, and also, if we had looked into a different - flotation - front axle/spindles, we may have had better performance. Despite all this, it wasn't a bad tractor. Other than these, the tractor had plenty of power (especially with the loader removed - took three men and a boy to do that). It would handle a two 16" bottom plow in 2nd gear without even a grunt. The hydraulics were strong and responsive. I don't know anything about the Oliver, but as far as the Ford goes, since it's the bigger brother to the one we had, it's probably a good machine.
Jim(UT)
01-13-2000 11:56:17
All these pro-Ford responses raises a question in my mind.....What would the responses sound like if the same question were posed on the Oliver board? I already looked and Mr. Kirk has not asked the Oliver folks yet.
Bob K
01-13-2000 17:29:54
 Re: Re: Ford 861 vs. Oliver Super 55/550 in reply to Jim(UT), 01-13-2000 11:56:17
Jim:
You literally took the words right out of my mouth as I was reading all these informative responses. Not that they are not valuable -- they are! But it did occur to me that I should see what the Oliver guys have to say.
Thanks to everyone for your helpful thoughts.
Bob
Rider
01-13-2000 07:36:40
I bought an 861 about 3 years ago. It has been excellent around here on my 5 acres as well as neighboring property. It is a wide front,power steering and 5 sp. trans. I use it with a brush hog, finish mower, blade and 2 b. plow. They are not that common in this area. I traveled about 5 hrs. to find and purchase mine. A seasoned, local, Ford tractor guru advised me on this model. Good luck. Rider
will
01-13-2000 04:44:41
Bob
I have used both and i would take the 861 over the 550 any time!!
Duke
01-13-2000 05:02:29
 Re: Re: Ford 861 vs. Oliver Super 55/550 in reply to will, 01-13-2000 04:44:41
I have a 861, been on our farm since 59', it has been a great tractor!!! It has never failed us yet!
Nick
01-12-2000 23:08:20
Bob,
I have an 800 series here that I use in the woods daily. It's very stable and surefooted, pulls like a mule team, and requires very little maintenance. I also have a 600, and the 800 does easily twice the work. Dunno about the Oliver, except for the horsepower difference. I do know that I can buy over the counter parts direct from Ford-New Holland for both of mine, so that's big incentive.
A rest-o-ride seat is a seat mechanism that uses a rube goldberg setup of rubber torsion bushings and steel link arms to keep your bottom from bottoming. It's all fully adjustable, having both elevation and windage adjustments.(!) I find them very comfortable. I just got done restoring one of mine a few months back, and it's loaded with expensive flanged bronze bushings. (about $80 worth!) It has a flip-up bucket that fits most human backsides, and also has some back and forward adjustment. A T-handled tension adjuster allows you to dial in more support as the years go by and you eat too many meatballs. One cautionary on them: If you store your tractor outdoors, at least keep the rest-o-ride seat covered. If you let it get rained on often, the h-shaped link rod ends that support the seat rust up, and they eat through the bronze bushings. The rods themselves are no longer being made, so I was forced to fabricate new ones. It's not an imposssible task, but you need a well equipped shop. If you browse around the various sites and look for Ford pictures, you'll find a shot of a rest-o-ride seat. You'll know it by the two big round rubber bushings that stick out from under the seat back. Other Ford tractors used a big bent spring for seat support. Hope this was informative! Regards,
Nick
paul
01-13-2000 07:30:09
 Re: Re: Ford 861 vs. Oliver Super 55/550 in reply to Nick, 01-12-2000 23:08:20
Nick, when you restored the seat, did you need the rubber bushings? Mine are shot, & I'm having a hard time finding any..... Thanks for any help.
The only glaring 'weak point' of a Ford of this era is if it has a Select-o-Speed transmission. They actually worked pretty good in their day, but require time & money to fix. SoS tractors seem to sell for 50% of the same tractor with a good 5-speed.
--->Paul
John
01-14-2000 18:56:11
 Re: Re: Re: Ford 861 vs. Oliver Super 55/550 in reply to paul, 01-13-2000 07:30:09
Paul;
861=5speed with live PTO
Nick
01-14-2000 00:24:50
Paul,
No, my rubber bushings were OK. They're no longer available, but even if they were, you would not pay the outrageous price that they had listed as the last price. They look pretty tough to make, especially the metal shells, and you'd have to find a company that still vulcanizes rubber to steel, a process that requires a lot of equipment and skill. Two possibilities.....scour the country for a good used set, or follow someone who has a set installed on their tractor. He's got to park it some time. (only kidding!) You're right about the SOS transmission lowering the price on tractors. The only experience I have with them is a neighbor's unit, that seems ok. My biggest criticism of them is that precise control in close quarters is very difficult. The innards of the SOS are not unique in the world of power transmission. If you understand the basics of planetaries and clutches and bands, and how they attain varying gear ratios, you should be able to maintain an SOS. The trouble seems to come when they get neglected. (what, us farmers neglect equipment??) A simple rule of thumb is that if you pour out the old lube and it forms a pile on the ground, you probably waited too long. Good luck finding the bushings. If I run into a set, I'll pass the word.
Regards,
Nick
Eric
01-12-2000 10:40:07
A good friend of mine has an Oliver Super 55 and I have a Ford 860. Both are nice utility tractors. A couple things about each tractor: The Ford doesn't really have live pto. It has two stage clutch which gives you the ability to stop the motion of the tractor with stopping the pto. The Super 55 does have an independent live pto. However, I believe that parts are easier to find for the Ford and that the Ford 861 is ~45 hp while the Super 55 is around 34 hp. Many of the 861's also came with power steering. I haven't seen many Super 55's with PS.
Both of these tractors are highly sought after tractors, so if you find one in good shape for a good price, I would say go for it.
Eric
