1919 Fordson Tractor
Mike
10-28-1998 13:44:11
I'm looking for information on a Fordson tractor. Ther serial no. is 81045. I've learned the serial no. makes it a 1919. I don't have any
information on what model it is. Can anyone help?
Mike
Don
10-29-1998 07:06:04
 Re: 1919 Fordson Tractor in reply to Mike, 10-28-1998 13:44:11
:Mike: You do have a 1919 Model F Fordson, produced at the Rouge plant in Dearborn. Does your radiator have 'ladder sides' ( 4 openings on the cast iron side piece?) You cannot always trust the engine serial number for the age of the tractor since they many times were swapped out of another tractor or replaced. Do your rear steel wheels have six spokes or six? Those two items plus the engine number should narrow down whether the entire tractor is of the same vintage.
I'm looking for information on a Fordson : tractor. Ther serial no. is 81045. I've learned : the serial no. makes it a 1919. I don't have any
: information on what model it is. Can anyone help?
: Mike
Don
10-29-1998 10:30:08
 Re: Re: 1919 Fordson Tractor in reply to Don, 10-29-1998 07:06:04
Oops, I meant does it have six or seven spokes.
: :Mike:
: : I'm looking for information on a Fordson : : tractor. Ther serial no. is 81045. I've learned : : the serial no. makes it a 1919. I don't have any
: : information on what model it is. Can anyone help?
: : Mike
Bill
07-19-1999 14:27:06
 Re: Re: Re: 1919 Fordson Tractor in reply to Don, 10-29-1998 10:30:08
: Oops, I meant does it have six or seven spokes.
: : : :Mike:
: : You do have a 1919 Model F Fordson, produced at the Rouge plant in Dearborn. Does your radiator have 'ladder sides' ( 4 openings on the cast iron side piece?) You cannot always trust the engine serial number for the age of the tractor since they many times were swapped out of another tractor or replaced. Do your rear steel wheels have six spokes or six? Those two items plus the engine number should narrow down whether the entire tractor is of the same vintage.
: : : : I'm looking for information on a Fordson : : : tractor. Ther serial no. is 81045. I've learned : : : the serial no. makes it a 1919. I don't have any
: : : information on what model it is. Can anyone help?
: : : Mike
I believe it is an X-9 series called a mom.
Mike
10-30-1998 10:37:12
Don,
The tractor does not have the ladder radiator. It has (6) spokes. Thanks for the
help.
Mike
: : : :Mike:
: : : Mike
