Fuel guage 12 volt
Ben
01-23-2000 14:58:58
converting my 801 over to 12 volts, will the gas guage work on 12 volts? Yes I know I should leave it alone, but its 2000.
Tony Jacobs
01-23-2000 22:40:33
 Re: fuel guage 12 volt in reply to Ben, 01-23-2000 14:58:58
Ben No it will not work,6 volt gas gauges and sending units are different than 12 volt gauges and sending units, The original 12 volt gas gauge from Ford is still available but the sending unit is discontinued, the diesel tractors were 12volt so you may be able to find a used one or send it out to a gauge shop and have changed to 12 volt, and yes the diesel parts are the same, thats how I do my conversions. Thanks Tony Jacobs
STUMP PULLER
01-23-2000 15:29:32
IF IT IS A TYPICAL FORD METER SYSTEM AND HAS A REGULATOR IT WILL WORK FINE. THE REGULATOR IN THE OLD STUFF IS A THERMAL HEATING TYPE SWITCH THAT REGULATES THE VOLTAGE TO THE METER SYSTEM.
