Hey Bern Nos. on 4 cyl. Industrial
2fordsmike
01-23-2000 17:40:08
Bern- I stumbled onto a Ford-Onan generator built for the Civil Defense that's for sale. Very little use in 40 years. It runs good. Always been inside with CD; then Iowa fire dept. But I haven't seen it. Wonder if the 4-cylinder engine would fit in Jubilee through 901. The seller gave this over the phone..... Type 4-9 1180 F2 8AR. I'm wondering if this is a 134 or 172 or some kind of 190 cu. in. that the local NH dealer says was also made. Can you help me with this. Thanks Mike-Iowa
Bern
01-23-2000 17:45:05
 Re: Hey Bern Nos. on 4 cyl. Industrial in reply to 2fordsmike, 01-23-2000 17:40:08
I wouldn't bet on it, but I really can't say for sure, as those numbers don't ring a bell with me. I'll print them out and run it past the parts guys at the store tomorrow and see what kind of an answer I can get out of them.
2ford
01-23-2000 18:05:41
 Re: Re: Hey Bern Nos. on 4 cyl. Industrial in reply to Bern, 01-23-2000 17:45:05
Thank you Bern. This can be bought for $1,250 which isn't bad if the motor is really good. I look forward to hearing what your parts man finds. Thanks again. Mike
Bern
01-24-2000 12:35:18
 Re: Re: Re: Hey Bern Nos. on 4 cyl. Industrial in reply to 2ford, 01-23-2000 18:05:41
Mike, I asked our two experienced parts guys (Mike and Mike, by the way!) if they recognized the numbers. Neither one could, although one said that it could well be very similar to the type of engine you are thinking about, since those type of industrial Ford engines were used in many different applications.
Sounds like you're gonna have to run over and take a peek at it for yourself, or else ask the owner if he can get some casting numbers off of the block that someone might recognize.
2fords
01-24-2000 14:52:47
 Re: Re: Re: Re: Hey Bern Nos. on 4 cyl. Industrial in reply to Bern, 01-24-2000 12:35:18
Bern Thanks for all of your efforts. Your expertise is greatly appreciated. You are a big help to many of us. Mike-Iowa.
