Order Ford 801 Parts Online
801 12volt conversion
Ben
01-25-2000 17:02:20
I just converted my 801 to 12 volts. Have one puzzle that has me stumped. I have a red light on my dash that used to indicate key was on but no charge from the generator. after starting the motor the light would go out. now I have voltage backfeeding from someplace to the side of terminal strip that should be off with key in off position. the same side of terminal strip has the little red light on it. Do I need to put a diode in line between the red light and the terminal strip to stop the feed back?
I have posted before and have always benifited from all the knowledge thats out there.
Thank You all.
John.CO
01-29-2000 00:52:23
 Re: 801 12volt conversion in reply to Ben, 01-25-2000 17:02:20
You have a GM one wire alternator with a 2-prong control plug? If so, the smaller plug wire is the exciter circuit and usually gets juice from the key. Put a diode in this wire to prevent the feedback. (1A, 50V, $.49 at Rat Shack).
tOTG
hunter
01-25-2000 19:25:06
yep, will proabaly run the battery down too.
Ben
01-26-2000 12:31:12
 Re: Re: 801 12volt conversion in reply to hunter, 01-25-2000 19:25:06
Thanks, I was hoping for a little more help than that.
