Order Ford NAA Parts Online
1953 NAA accessory hydraulics
Joe Steele
01-27-2000 08:09:07
An old fellow down the road needs some help locating this part. He calls it an "accessory hydraulic kit" He says its nothing more than a 2-way spool valve that mounts with 5 bolts, and has 2 .50" outlets. By the way, this tractor is in perfect condition, and is used regularly.
John.CO
01-29-2000 00:37:26
 Re: 1953 NAA accessory hydraulics in reply to Joe Steele, 01-27-2000 08:09:07
I put one on my Jubilee and had to replace the whole top cover. It wouldn't bolt up like the later XX0 models.
I modify that little cover plate to route oil through an open center remote valve, then back to run the 3-point. Works good. Mail me if you want info.
tOTG
Tim Brown
01-29-2000 09:12:53
 Re: Re: 1953 NAA accessory hydraulics in reply to John.CO, 01-29-2000 00:37:26
what kind of hyd pressure can you get?is enough to run a wood spliter or lift a small disc?
