Order Ford 3000 Parts Online
3000 fuel gauge doesn't work
RWK in WI
11-08-1998 08:35:16
I'm looking for ideas on what to check next. My 3000's fuel gauge worked fine for years then last winter some days it would work other days it stayed at E. This summer took gauges out. I get an amp meter reading coming from the wires at the gauge and at the tank sending unit. But can't get the gauge to move. I have been afraind to put full 12 Volts to the gauge to see if I can break it loose. Any help?
Also same tractor the Alt. light won't come on even with the key on before starting the engine. Have tried new bulb but still the same.
Oil light and temperature gauge in the same panel work fine. Thoughts?
Thanks
Dick Kraus
CW
11-08-1998 17:38:54
 Re: 3000 fuel gauge doesn't work in reply to RWK in WI, 11-08-1998 08:35:16
: Have you taken the gauge out of the tank. My 3000 the float came off the end of the senor arm. Filled the tank and got a hold of the float and put it back on. Hasn't come loose again in the past 3or4 years. CW
