Old fordson
bob lewis
11-14-1998 06:27:24
a friend has a old fordson tractor, some where in the twenties. where is serial # location or
how else can we find out what year it is. any and all help is needed. thanks bob.
Don
11-16-1998 08:23:00
 Re: old fordson in reply to bob lewis, 11-14-1998 06:27:24
Bob: You will need to look at the right hand front side of the engine, between the intake and exhaust ports of the No. 1 cylinder. The serial number of the engine will be stamped on the flattened boss just below head/block junction. Let me know the number and I'll give you the year of manufacture. Keep in mind the engine number will not always accurately reflect the age of the tractor because many engines were replaced. There are a variety of methods of determining if the engine number may be original to the tractor, such as number of spokes in the rear drivers, 1 or 2 fuel tank bungs, presence or absence of Patent numbers on the dash, size of oil drain plugs, etc etc. Your tractor is most likely an 'American Model F'. Good luck.
: a friend has a old fordson tractor, some where in the twenties. where is serial # location or
: how else can we find out what year it is. any and all help is needed. thanks bob.
