4040 diesal fuel in crankcase???
Al Milono
02-21-2000 17:38:01
Have 4cyl diesal with Roos Master inj. pump.
crankcase is contaminated with fuel.
fuel returns seem to be operating properly.
using a later model pump, original pump has
small valve(?} in return line to tank that is not
on newer pump.
Engine runs well Any ideas or comments would
be appreciated
Thank You
Al Milono
02-23-2000 18:42:34
 Re: 4040 diesal fuel in crankcase??? in reply to Al Milono, 02-21-2000 17:38:01
Thanks for the help !!!!
Leaking lines under valve cover...
replaced line and new seals problem seems solved
twopop
02-21-2000 18:48:55
THERE IS A SEAL AROUND THE SHAFT THAT DRIVE THE PUMP,TO KEEP THE FUEL SEPARATED FROM THE OIL AND THIS SEAL IS PROBABLY LEAKING.
Tony Jacobs
02-21-2000 19:37:16
 Re: Re: 4040 diesal fuel in crankcase??? in reply to twopop, 02-21-2000 18:48:55
Al The most common cause of fuel in the oil on these diesels is the return line that connects to the top of the injectors, it is located under the valve cover, they crack from vibration, it is such a common problem that I replace them anytime I do any fuel system work or have the valve cover off, for work. Thanks Tony Jacobs
