Tempature gauge
BOB in pa
02-26-2000 18:07:04
i have a 41 9n anybody drill the head where is a flat boss by upper water neck on head. looks like it would accept temp. gauge? thanks good site
will
02-27-2000 04:01:33
 Re: tempature gauge in reply to BOB in pa, 02-26-2000 18:07:04
Bob, I have drilled that flat boss and tapped in a temp guage. Works real well. thats the easy part. The hard part is finding a low range temp gauge.
Bern
02-27-2000 08:44:30
 Re: Re: tempature gauge in reply to will, 02-27-2000 04:01:33
I'm curious now. Just how low of a range does this gauge need to be? Most conventional temp gauges go down to 100 degrees F, and I'm sure the N's run warmer than that.
STUMP PULLER
02-27-2000 19:30:59
 Re: Re: Re: tempature gauge in reply to Bern, 02-27-2000 08:44:30
I AM USING A SENDING UNIT FROM A 57 TO 62 FORD CAR OR TRUCK. PN R134 1/8NPT 18 THDS PER INCH. USING A THERMAL GAUGE FROM A FORD TRUCK. ABOUT 1980. WITH 8 VOLTS APPLIED TO THE SYSTEM THE GAUGE READS ABOUT MID SCALE.
Bern
02-27-2000 19:55:35
 Re: Re: Re: Re: tempature gauge in reply to STUMP PULLER, 02-27-2000 19:30:59
And from all that, how do you know what the overheating point is, or for that matter, if your setup is even accurate?
STUMP PULLER
02-27-2000 20:10:08
 Re: Re: Re: Re: Re: tempature gauge in reply to Bern, 02-27-2000 19:55:35
CHECKED IT ALL ON THE BENCH. TEMPERATURE REF OF 212 DEG BOILING WATER.
Bern
02-27-2000 22:16:56
 Re: Re: Re: Re: Re: Re: tempature gauge in reply to STUMP PULLER, 02-27-2000 20:10:08
OK, that works for me. That leads me to my next question: Just what do you (or anyone else out there) consider to be the danger point as far as overheating goes on an "N"? Evidently Will up above thinks it's pretty low, as he had a hard time finding a temp gauge "that would go low enough". I'm still scratching my head on that one.
