1962 Ford Industrial Model #
R Johnston
02-27-2000 10:00:38
My model # reads 20302 the information I have says there should only be four digits. Also my sheet metal is of the 601/801 type.
Jim(UT)
02-27-2000 21:15:54
 Re: 1962 Ford Industrial Model # in reply to R Johnston, 02-27-2000 10:00:38
Here's a site that should help you determine the year of your tractor from the serial number:
Peter Sotham
06-02-2006 14:56:19
 Re: Re: 1962 Ford Industrial Model # in reply to Jim(UT), 02-27-2000 21:15:54
I have installed in a boat a 1962-3 Ford Diesel Industrial 4 cyl 58-59 HP engine. The engine number is # S438407. Any idea what site I can log onto to find parts and manuals?? Thanks. Peter
Bern
02-27-2000 13:01:15
A 5 digit number indicates a tractor built between 1962 and 1964. Here is the breakdown on 20302:
The first digit "2" indicates it has a 134 CID gas or 144 CID diesel engine.
The second digit "0" indicates an industrial model produced prior to 1963.
The third and fourth digits "30" indicates a four wheel, utility type industrial, with a non adjustable front axle.
The fifth digit "2" means it has a four speed transmission, hydraulic system, and no PTO.
