Order Ford NAA Parts Online
1953 Ford Golden Jubilee Tractor
Donald P Carpen
02-27-2000 21:13:26
Cooling System: Put in new radiator. Still get hot and boils over. What are the possible solutions: Thermostat, waterpump?
Jim Coleman and Joan Swafford
05-09-2001 09:39:38
 Re: 1953 Ford Golden Jubilee Tractor in reply to Donald P Carpenter, Sr., 02-27-2000 21:13:26
I have a chance to buy a 1953 golden jubliee model ford tractor in excellent condition. What is the value? Can you help. Thanks Jim
tlak
02-28-2000 05:06:37
Usally if you look in the radiator while its running you can tell if the pump is curculating water by the movement.
If the thermostat is stuck closed the eng will get hoter that the radiator first but then the heat transfers on out to the radiator because you dont have good circulation. You can remove the thermostat and run it without. The eng will take longer to warm up but not overheat.
You could have a busted head gasket.
Make sure your fan belt is tight.
Do you have a fan shroud? This increases the flow of air.
Carlos
02-28-2000 20:27:18
 Re: Re: 1953 Ford Golden Jubilee Tractor in reply to tlak, 02-28-2000 05:06:37
Look for big air bubbles in radiator.
This could be compression loss from
a blown head gasket. Some times no
thermostat also makes big bubbles
as water circulates to fast and
creates cavatation. also if it
circulates to fast the water has no
time to really get cool.
GOOD LUCK!
Carlos
tlak
02-29-2000 07:07:05
 Re: Re: Re: 1953 Ford Golden Jubilee Tractor in reply to Carlos, 02-28-2000 20:27:18
I missed that one. I didnt think of it not even having a thermostat.
