Order Ford 4000 Parts Online
4000 engine problems
Al Paschall
03-07-2000 07:03:50
I have a 1967 4000 gas burner, 3 cylinder. I can drive it for about 30-40 minutes doing something heavy like discing or breaking and the engine will start to lope almost dying then revving back up. If I turn it off for just a couple of minutes it will run ok for about 5-10 minutes then do it again.
I just had it tuned up and it seemed to have no effect.
My uncle owned the tractor before me. When the fuel pump went bad he just cut it out and made it a gravity flow. It's been that way for 4 years now and only in the last few months has this happened.
I think it is a fuel problem but don't know where to begin looking. Filter, carb, ???.
Any help would be appreciated.
Al Paschall
Humboldt, TN
GEO
03-07-2000 18:58:26
 Re: 4000 engine problems in reply to Al Paschall, 03-07-2000 07:03:50
Al,
You might check the strainer fitting that is connected between fuel line and the carb housing. I have had to take carb off to get at it. It looks like a fuel line adapter. If this is not the problem you might check the coil as well.
Hilltopper
03-07-2000 08:34:55
Try taking off the gas cap just as soon as it starts quitting. The vent in the cap may be plugged. Also, I had an old 6000 industrial backhoe and front bucket. Had so much rust in the tank it wouldn't run very long. I drained the gas and put a 2 inch nipple on top of the gas valve to keep the rust out of the line. The old engine mounted pump failed so I put an electric pump on it and the rust would plug it up until I got the nipple in.
