Order Ford 4000 Parts Online
4000 Diesel seepage
Dewey
03-10-2000 04:21:45
I own a Ford 4000 diesel and there seems to be seepage between the head and the cylinder block at various places. I'm a novice tractor owner and would greatly appreciate any ideas that you could give me. Is the seepage due to an improperly torqued head or something more serious? What can I do to correct the problem? Thank you for any advice that you can give.
twopop
03-10-2000 17:11:40
 Re: 4000 Diesel seepage in reply to Dewey , 03-10-2000 04:21:45
You pobably do have a head leaking due to either loose head bolts or the engine may have gotten hot.the first thing would be to retorque the head and see if the lEAKS STOP. If they dont you will need to replace the head gasket and have the head checked fo warpage.
