Order Ford 3000 Parts Online
3000 Compression?
Windancer
03-18-2000 02:00:44
I'm checking that '74 Ford 3000 that's
for sale. What could one expect to see
as compression numbers? It has 2,500 hours
on it. What would be considered unacceptable?
Bern
03-18-2000 11:26:36
 Re: 3000 Compression? in reply to Windancer, 03-18-2000 02:00:44
Gas engine: 120-150 PSI with all plugs removed and choke and throttle wide open. 25 PSI cylinder to cylider variation.
Diesel engine: 350-400 PSI with all injectors out (6-8 puffs, 200 RPM cranking speed). 50 PSI cylinder to cylinder variation. Diesel engine will be hard starting in the cold with anything under 300 PSI.
