Order Ford 3000 Parts Online
3000 Select-o-Speed Xmsn
John Sigman
12-04-1998 11:06:12
My father-in-law has a '66 3000 Ford with S-o-S.Shortly after a trip to the shop a long time ago, every other speed (1-3-5-etc)quit working.No grinding or funny noises and the operable gears work fine.Several years later, another trip resulted in the same problem.I think something may have been left out.Now,I can't find a mechanic that knows how to work on S-o-S xmsn. Any suggestions on how to fix it?
John Sigman
12-15-1998 19:28:47
 Re: 3000 Select-o-Speed Xmsn in reply to John Sigman, 12-04-1998 11:06:12
: My father-in-law has a '66 3000 Ford with S-o-S.Shortly after a trip to the shop a long time ago, every other speed (1-3-5-etc)quit working.No grinding or funny noises and the operable gears work fine.Several years later, another trip resulted in the same problem.I think something may have been left out.Now,I can't find a mechanic that knows how to work on S-o-S xmsn. Any suggestions on how to fix it?
As an update, its only four forward gears (1,3,5, and 7) that don't work. They are controlled by clutch #3. Does this mean that something was left out or out of adjustment? Thanks. John
Kevin
12-04-1998 20:55:01
Where are you located?
Dan
12-04-1998 15:03:20
The malfunction you describe does not fit exactly into what we might call "classic" S-O-S malfunction descriptions. You might take a look at A Troubleshooting Guide for the Ford Select-O-Speed Transmission . Find your malfunction (be specific) then look thru the diagnosis guide.
I would guess that your overrunning clutch is not releasing.
Dan
NAA60512
Norm
12-04-1998 14:44:32
Get a different tractor the sos will cost several thousand dollars to fix. They were the worlds tranny
