Order Ford 4400 Parts Online
4400-backhoe
Tony
04-06-2000 15:43:49
I have a 4400 ford with a "series 750" backhoe on it. Can anyone tell me what holds the hydraulic cylinders in that turn the boom. one is loose & I can't figure out what is holding the other side in. Thanks in advance.
D Smoker
04-06-2000 16:24:02
 Re: 4400-backhoe in reply to Tony, 04-06-2000 15:43:49
The cylinders aren't fastened to anything. They lay in holders loose, the swing chain tension holds them in place.
Tony
04-06-2000 16:52:24
 Re: Re: 4400-backhoe in reply to D Smoker, 04-06-2000 16:24:02
Thanks D Smoker, is there any way to tighten the chain tension, the r/h cylinder is quite loose.
D Smoker
04-08-2000 16:50:10
 Re: Re: Re: 4400-backhoe in reply to Tony, 04-06-2000 16:52:24
If the cylinder seems loose a few things could be happening. There is a bunch of dirt packed around the cylinder,ours used to do this if you worked in deep mud. The swing chain could be worn or the bracket the cylinder pulls against could be bend or worn. We had one that wore the swing post were the chain rides that badly we had to replace the swing post. I'd check for dirt or worn parts. If I remember correctly the cylinder lays in bracket where the rod comes out and one back a little farther where the hose comes out of the cylinder. One other possiblity is that the internal cylinder packing is bad and when there is no pressure on it it's letting the chain loosen up.
Good luck!
Darrell
