Order Ford 9N Parts Online
Timing on a Ford 9N Tractor
Adam
04-07-2000 16:15:31
I need to know the proper way to set the timing on this tractor!
Dell(WA)
01-20-2004 15:36:22
 Re: Timing on a Ford 9N Tractor in reply to Adam, 04-07-2000 16:15:31
I'm guessing that you are to cheap to buy a FO-4 because your here wasteing our time.
respecfully Dell
Jerry
04-07-2000 17:17:25
Hello Adam,
The N-Tractors are some tough ones are they not.
They can take anything.As far as your timming
its real easy,just line up the timing mark on
your crank gear and cam gear.One mark will be between one with two teeth?hope this helps!
