Order Ford 841 Parts Online
1841 Carb Overhaul
Tony M
04-09-2000 14:16:12
My 1841 Industrial does not run between idle and full throttle, unless I give it some choke. I found no screen in the glass fuel bowl, so the carb is probably dirty. The carb is a Marvel-Schebler TSX-813. A dirty TSX-662 carb also came with the tractor, which is probably the original unit. Does any one have thoughts about what is the difference between the carbs or is just the manufactured date?
Thanks, again.
Tony
