1959 Ford 641 Workmaster gas tank sending unit
Don from Jackso
04-13-2000 09:26:46
I need to replace this or repair it. any ideas?
J.Coleman
04-14-2000 16:12:35
 Re: Re: 1959 Ford 641 Workmaster gas tank sending unit in reply to Billy, 04-13-2000 14:40:53
I have a 1963 641 that had the same problem. I found the problem with mine was it was not grounding good where the float bolt on to the top of the tank. ( I hope I'm making myself clear..lol) I used some sand paper to clean it to the bare metal making sure not to get any grit in the tank then reinstalled it and the sending unit starting working fine. I don't know if this is your problem of not but it worked for me. Hope this helps and good luck!
