Order Ford 971 Parts Online
1971 Ford 2000 PTO
STEVE
04-21-2000 18:40:20
the PTO will not engage unless motor is off or you have enough strength to force it into position. When motor is off PTO lever will go down fairly easy. Is there a adjustment for the lever? Thanks
Bern
04-21-2000 22:42:04
 Re: 1971 Ford 2000 PTO in reply to STEVE, 04-21-2000 18:40:20
There is no adjustment for the engagement lever. It sounds like problem is with your clutch, it is not releasing all the way. How much free play do you have in your clutch pedal right now? If it is over 2", try tightening it up to around an inch or so, and see if that helps. If not, you likely have problems with the PTO stage of your pressure plate, requiring a tractor split to repair. Regardless, do not keep trying to force the lever into position. You will eventually damage the driveline coupler and teeth.
RWK (WI)
04-23-2000 14:55:22
 Re: Re: 1971 Ford 2000 PTO in reply to Bern, 04-21-2000 22:42:04
One more thought if it a two stage clutch it may be set to only disengauge the drive train. There was a pin adjustment for this if I remember correctly.
Dick
