Order Ford 3000 Parts Online
3000 steering
tom
04-24-2000 18:12:06
got a problem, when I turn the steering wheel left, it's like it unscrews up out of the colum,it will turn right o.k. is there a nut or something that might have come off? where do I start? thanks
tom
04-27-2000 07:39:06
 Re: 3000 steering in reply to tom, 04-24-2000 18:12:06
got the shaft outand there wasn't a bearing left on the top or bottom.I got a handful of rollers and part of a bearing cage out of the bottom. I called 3 ford dealers to find pieces and price, got 3 different prices, from 12 to 30.00.guess I'll take the parts and go to one of the dealers and see what I get.
Bern
04-26-2000 14:01:34
Hilltopper is right. You probably have the top bearing going out. There is no such thing as a plastic bearing of some sort for a replacement however.
Make sure you remove and disassemble the entire box to make sure you get out all the little rollers that fell to the bottom.
Hilltopper
04-26-2000 16:49:38
 Re: Re: 3000 steering in reply to Bern, 04-26-2000 14:01:34
Bern, they make a plastic type steering gear thrust bearing cup for Fords up to 1964. It replaces the race and the bearing. I would think they would last but a few years of heavy work. I would not use them unless I couldn't find a standard bearing. I am glad they are making these old parts more available now. I used to spend weeks trying to locate new parts. Good Luck.
GEO
04-26-2000 21:28:55
 Re: Re: Re: 3000 steering in reply to Hilltopper, 04-26-2000 16:49:38
You are correct Hilltopper about the plastic (called moly bearing). I sold a few when they first came out. They don't hold up to well.
Hilltopper
04-24-2000 20:01:55
The upper bearing in the shaft tube just above the gear box (not the upper bearing near the steering wheel) has probably fallen apart if it is anything like the older N models. New bearings are available, I think, but they make a plastic one to replace it. There are two in a set, both the same, and cost less than twenty bucks. Then again you might have more serious problems. You need a manual to get the sectors back in right and adjusted. I am not familiar with a 3000 steering gear per se but it sounds like the upper bearing has let go. Good luck.
