Order Ford 3000 Parts Online
3000 transmission oil seal
CAM
04-30-2000 04:36:36
I have my 3000 apart doing a clutch job. While inside I have replaced the rear engine oil seal and the small seal that goes in the end of the pto input shaft. The book shows a seal in the clutch release bearing support. The support also seems to hold a bearing. The seal seems to be seeping slightly. Are there any surprises if I pull the clutch bearing support to replace the larger seal?The job looks simple, but those simple jobs sometimes cause the biggest headaches.
