Pinion Gear Stepped Dowel Pin
Alk
05-26-2000 10:57:06
I'm in the midst of replacing the pinion gear on my NAA. I see in the manual a "stepped dowel pin" located on the pinion end going to the drive coupler. My tractor was missing it, and Ford no longer sells it.
What good is the thing anyhow?
Bern
05-26-2000 22:48:42
 Re: Pinion Gear Stepped Dowel Pin in reply to Alk, 05-26-2000 10:57:06
I do believe that you're looking at the dowel pin for the bearing retainer. The picture in my book at first glance makes it appear to be inserted into the end of the pinion shaft, but upon closer inspection, it has dashed lines running from it to one edge of a small hole in the bearing retainer. Look in the backside of your retainer, I'd bet you'll find it.
Alk
05-30-2000 04:55:22
 Re: Re: Pinion Gear Stepped Dowel Pin in reply to Bern, 05-26-2000 22:48:42
Sorry, I forgot to mention that my tractor is an NAA. Thanks for your reply. I'll take a closer look for the pin.
