Lockwasher on pinion gear
Alk
05-26-2000 11:01:00
Does anyone know where I can get the lockwasher (with bend tabs) that goes between the two large nuts on the pinion gear? Ford says they don't carry them any longer
Sam Mills
05-27-2000 04:11:39
 Re: Lockwasher on pinion gear in reply to Alk, 05-26-2000 11:01:00
You don't say which model you are repairing but, I just rec'd today (2) nuts and tab washer from FNH. Part number of nuts is 353700S8, and washer is NCA4636A. My tractor ia a 601.
Alk
05-30-2000 05:02:01
 Re: Re: Lockwasher on pinion gear in reply to Sam Mills, 05-27-2000 04:11:39
Sorry, I forgot to mention that my tractor is an NAA. What do you think the difference is for the one for a 601?
Bern
05-26-2000 22:52:13
If the dealer can't get them, take the old one (or the pinion and nuts) to a diesel truck shop. Buy the closest lock tab washer for a truck transmission you can find and modify it to fit. They're just stamped steel pieces, I'm sure you can make almost any one work for you.
Alk
05-30-2000 05:05:04
 Re: Re: Lockwasher on pinion gear in reply to Bern, 05-26-2000 22:52:13
Sorry, I forgot to mention that my tractor is an NAA. Truck transmission shop sounds like a good place to look. Thanks!
