FLAIL MOWER
BOB STRATTON
05-30-2000 14:18:28
I'm Considering purchasing a flail mower . I've located a Ford model 917H that is a 90" cut. What size tractor is needed for proper operation. I have a 8N But have been considering a Ford 3000. The asking price for the mower is 1320.00 and is said to be in excellent condition. Is this a fair price?. Thanks
DAN
10-09-2000 08:40:12
 Re: FLAIL MOWER in reply to BOB STRATTON, 05-30-2000 14:18:28
I HAVE A 88" FLAIL MOWER
IT TAKES AT LEAST A 45 HP TRACTOR TO PULL IT
A 8N IS ABOUT 27 HP
A 3000 IS AROUND 35-45(DEPENDING ON THE MODEL)
MarkB
06-01-2000 03:09:38
Do not try to run a 90" flail mower with your 8N. You need 40-50 HP. A 3000 should be fine.
If the mower is in very good condition, $1320 is probably a fair price. Check the condition of the roller & shaft bearings, knives, etc.
I have an ancient 6' Mott that I run on my 4 cyl. Ford 4000. It works well. I paid $450 and it was pretty beat up.
Tom
05-31-2000 16:51:40
I have a Matthews 72" flail that I run on a 640. The Ford handles it OK, but I wouldn't go any larger with that tractor. Don't think it's possible to run a 90" flail on an N.
I paid $500 for my flail used. The unit costs $4500 new. But what constitutes a good used price might vary.
Flails bounce alot. Check the unit you are looking at for hairline cracks anywhere. You might get the price down more.
Good luck
Tom
Joe Sawyer
05-31-2000 06:20:58
I run a 90" Ford flail mower behind my 2600.
It is a bit heavy for the tractor but my ground
is very flat so I can get away with it. I am
not sure of the recommended HP for a mower of this
size but my tractor is around 33 PTO HP. By the
way I paid $550 for mine, it was used by a local
township for maintaining parks and roadsides.
Hope this helps in your decision.
Joe
Al PA
05-30-2000 16:46:08
I have a Ford model "917L Special" which is a 60" cut. I have run it on both my 8N and my 3000. It is about as large as you want to go with an 8N (don't forget the over-running pto clutch). However, it works really great on the 3000 which has live pto and live hydraulics. The 917H you've described is probably a little large even for the 3000 - way too big for the 8N. By the way, I paid just over $1,000 for my mower: It was new, but the dealer had it in inventory for a while.
As for the Ford 3000, you will love it. Get the 8 speed, manual transmission (not the SOS)and try for one with power steering. All your implements will work fine on it - actually better than on the 8N.
