Order Ford 3000 Parts Online
3000 Diesel tranny question
Bob
06-10-2000 05:58:09
This was reposted for BOB by truck...
"just bought a 3000 diesel and had the brakes checked, ...the brakes are ok, seems the tranny is always working, even when the clutch is in,...HELP!!!!! ....any adjustments or other remedies other than rebuilding or replacing the tranny? "
Bern
06-10-2000 20:03:37
 Re: 3000 Diesel tranny question in reply to Bob, 06-10-2000 05:58:09
If it's a manual tranny, sounds like the clutch disc is stuck to the flywheel. Get it rolling in gear (preferably a higher one), step on the clutch and STOMP on the brakes! Be careful, this can be dangerous!
Truck
06-10-2000 06:03:05
Bob, is this a Selectospeed with the shifter just below the steering wheel or a standard transmission with a conventional clutch? If it is a Selectospeed you might want to start out with a fluid and filter change.
If it is a conventional transmission, you would want to check out your pedal free play. If it is correct you might have a frozen clutch disc. Sometimes they will rust and stick to the flywheel and pressure plate. Some on this forum have reported good results with shocking the drive train or putting heavy loads on it while HOLDING THE PEDAL IN, to break free the rust.
Stringbean
09-29-2000 16:51:55
 Re: Re: 3000 Diesel tranny question in reply to Truck, 06-10-2000 06:03:05
If it's a manual tranny, you may have a damaged pressure plate. The clutch arm, and linkage rod, are"low" on the tractor, and prone to getting hit, or snagged. The action of pushing the lever back too far can happen from catching a stump, or root, or could happen because of the linkage rod being bent. Both will "over activate" the clutch fork, which in turn can bend the fingers on the pressure plate. I've done both, so this is the voice of experience. A new pressure plate is the only cure, if this is what's happened.
