Order Ford 600 Parts Online
5600 Ford Diesel
Bonnie Fuchs
06-15-2000 09:23:04
Help on adjusting clutch out or replacing clutch.
Is this a inshop job or shade tree? What is the best shop manual to get for this?
Bern
06-16-2000 22:01:02
 Re: 5600 Ford Diesel in reply to Bonnie Fuchs, 06-15-2000 09:23:04
Clutch pedal free play is adjusted by turning clevis in or out as needed to obtain roughly one inch of free play at the top of the pedal. Free play is defined as the amount that you can push down the pedal very easily until you meet stiff resistance.
As far as replacing the clutch, you need (among other things) a good size floor jack and a smooth cement floor. Only you can determine whether you're qualified or not to actually do this job. It's not technically challenging, mainly just grunt work.
For a good manual, I find that the factory manuals are the best (available from a NH dealer), however the I&T manuals will suffice also.
