Order Ford 9N Parts Online
9N Ford
April Hileman
06-19-2000 20:09:54
I have a 9N that was running just great until night before last my Husband took it out used it then parked it in the drive now it won't start . I did a complete tune up points ,plug ,plug wires,condensor ,rotor ,and dist cap . Still won't start . It has some fire to the plugs . its getting fuel . I'm totally puzzled any help appriciated .
Jim.UT
06-19-2000 21:41:25
 Re: 9N Ford in reply to April Hileman, 06-19-2000 20:09:54
It's getting "some" spark or "good" spark? Is the spark at the plugs bright blue? Also, you might get more response posting this question on the N-board (same site). This one covers mainly Ford tractors manufactured after the N series.
April Hileman
06-19-2000 21:46:08
 Re: Re: 9N Ford in reply to Jim.UT, 06-19-2000 21:41:25
The spark is white I also posted on the other board I found this one first .
April Hileman
06-19-2000 21:45:55
Orlando
07-05-2000 09:25:03
 Re: Re: Re: 9N Ford in reply to April Hileman, 06-19-2000 21:45:55
april...did you get it started? i've got the same
problem with my 48 8n. please let me know.
orlando
April Hileman
07-05-2000 20:41:56
 Re: Re: Re: Re: 9N Ford in reply to Orlando, 07-05-2000 09:25:03
No not yet I'm Covinced I've got a ground problem somewhere though cause there isn't any thing else to change out left now I'm going to go through and wire brush every thing tomarrow to make sure every thing thats suposed to be is making contact gotta have the other half help me get the hood back off though
bill
06-23-2000 13:46:24
I know little about mech. but I had a similar problem. The insulation on the ground wire(i think) coming out the bottom of the distributor had worn through and was grounding to the metal.
I had to remove the wire to see it. I had replaced lots of parts before an old timer related his experience to me.
