Order Ford 2000 Parts Online
2000 Ford
Michael
12-20-1998 11:17:15
A friend has a 2000 ford 6 sp trans,3cyd diesel, fair rear tires,frt are shot,steering has bout 4" travle before tire's start turning,says it blows oil but runs great? wants $2500 with 5'bushog how hard is it ta fix the steering,will surly have ta replace the rings think its worth it?
RickB.
12-20-1998 15:54:03
 Re: 2000 Ford in reply to Michael, 12-20-1998 11:17:15
You may be in for more than you want. The steering may be spendy to fix, and the 3cly is a great motor, but without renewable sleeves, you will be gambling that the bores are good and a set of rings will cure it. You could easily spend $1000 to $3500 to address these two problems.
