Order Ford 9N Parts Online
1943 Ford 9N
Ken Davis
06-29-2000 22:32:11
Just purchased and must trailer to its new home. Please, what is its approx weight w/o implements.
Jim.UT
06-30-2000 20:25:01
 Re: 1943 Ford 9N in reply to Ken Davis, 06-29-2000 22:32:11
Not to nitpick, but if it's a 1943, it's a 2N. Both 9N (1939-1941) and 2N (1942-1947) had serial numbers that started with "9N". Learn more at Nseries.com and/or Smith's page. Have fun with it!
Ken Sarge Davis
07-02-2000 01:29:19
 Re: Re: 1943 Ford 9N in reply to Jim.UT, 06-30-2000 20:25:01
I visited Nseries.com and I would agree that it indicates 9N's were not produced in 43, except for one little detail. Within YesterdaysTrackers. com listed under Serial Numbers for 9N's it provides 1943 serial numbers beginning 105412 & stamped on the side of my tractors block is the serial number 9N176313. So one of these websites is incorrect and I since my tractors other features are 3 speed, 6 volt elect system, I feel your source is incorrect. Sarge
Jim.UT
07-02-2000 14:26:34
 Re: Re: Re: 1943 Ford 9N in reply to Ken Sarge Davis, 07-02-2000 01:29:19
9N and 2N were both 6 volt with 3 speed transmissions so there isn't any way to tell the difference between a 9N and 2N based solely on the battery and transmission. Every source I've looked at regarding serial numbers says the 9N was produced up through serial number 99002 or 99003 (I forget which) afterwhich the tractors were considered 2N tractors even though the serial number starts with "9N" all the way to the end of 2N production in 1947.
Walter
06-30-2000 05:10:16
It should be about 2550 pounds. Check this site for more info: Link
