Order Ford 2000 Parts Online
2000 6 to 12 volt conversion
Red
07-04-2000 17:01:06
I just converted my 2000 from 6 to 12 volts. I installed an alternator and wired it according to the instructions. It started, ran good, charged as it should. I shut it off and now pushing down the starter does nothing. The ammeter shows discharge when the switch is on but nothing when the starter is depressed. What happened?
Tom Washburne
07-07-2000 11:12:10
 Re: 2000 6 to 12 volt conversion in reply to Red, 07-04-2000 17:01:06
I'll take a guess: You forgot to change the starter relay and perhaps you burned it out? I don't know if they are voltage sensitive or not, or whether you have to reverse the contacts, etc.
