Order Ford 3000 Parts Online
3000 SOS Front seal went today....
truck
07-11-2000 16:11:20
Well finally a fatal blow happenned to the SOS 3000 I have. I was doing some box blading when I noticed I was dripping some major oil from the bellhousing area. There is a small hole on the bottom that was leaking a 1/4 inch stream of tranny oil, and there were some new leaks by the starter and hydraulic pump that weren't there before. I shut it down and got the drain pans.
I looked through the archives, found out these seals should be loctited in place, but no other info. Am I correct in assuming the front seal on the transmission went?
How long should this job take a halfway competent tractor mechanic?(I can do a 8N clutch in about half a day, counting breaks and goofing around..)Anything else I should do while I'm in there?
Thanks for the help!
samco
07-11-2000 20:17:03
 Re: 3000 SOS Front seal went today.... in reply to truck, 07-11-2000 16:11:20
check the input shaft splines. that is a weak a weak spot on these transmitions. the splines that go into the torque limiting clutch.
Dave Tief
07-11-2000 20:05:47
I am not sure about the possible differences in the model number, but I had to replace the front seal on my SOS transmission. I had to remove the engine, and then the 4 bolts that hold the oil pump on. pop out the old seal, press in the new. I did the rear main and front main also, as they were shot as well.
Dave
RIckB.
07-11-2000 17:47:32
I would change the 2 frost plugs in the back of the block & the one in the back of the head. Consider a new rear main crank seal, too. Can't help w/ SOS issues; haven't had the pleasure, yet anyway.
