Order Ford 4000 Parts Online
4000 PTO question
CAC
07-17-2000 10:49:55
Is the PTO on a 4000 suppose to engage smoothly. Mine doesn't. When I engage the PTO there a banging from the brush hog as it starts suddendly. It is not the brush hop, because I have used two different ones and they both do the same thing. Also, when the PTO is not engaged the brush hog still spins until it hits heavy grass.
Jeff
07-20-2000 10:43:24
 Re: 4000 PTO question in reply to CAC, 07-17-2000 10:49:55
I just recently completed some work on my 4000 PTO. Not sure what model you have but I have an independant PTO which is ingaged by the hydrolics. I usually idle mine down and engage it with a slight banging noise. However, with the independant PTO, the hydrolics should open up a brake and engage a clutch to start your PTO somewhat gently. My brush hog will stop spinning and I can not move my PTO by hand with PTO disengaged. Its probably no big deal, maybe your brake or the springs on your brake for you PTO are a little worn. (If this is the type of PTO you have.)
cac
07-21-2000 19:09:35
 Re: Re: 4000 PTO question in reply to Jeff, 07-20-2000 10:43:24
After looking at the operator's manual it looks like I have live PTO. Would this have a brake similiar to an independent PTO?
What is meant by double clutching?
CAC
07-21-2000 05:29:42
I have a mid to late 70s model 4000. I assume it would have an independent PTO, but I am not sure. From what I have read on previous messages, it sounds like the brake on my PTO has worn down. Is this a costly repair to get the brake fixed? What are the dangers of not doing it? If it is an independent PTO it shouldn't "push" the tractor if I am trying to stop. Right?
Tom Washburne
07-18-2000 08:45:48
My 800 (the forerunner to the 4000) bangs when you put the bush hog on. I don't think the bang comes from the PTO in the tractor. I usually just clutch twice to put less stress on it until it comes up to speed. I never thought much about it. If this is a problem, I would like to know! I think that all bush hogs spin until the the blades stop naturally.
