Order Ford 4000 Parts Online
4 cyl 4000 smoking
Bud
07-31-2000 05:14:00
Am looking at a 62 4000 4cyl for sale. It cranks right up but smokes for ten minutes or so then quits. It is a diesel. Any thoughts?
Bern
07-31-2000 18:21:33
 Re: 4 cyl 4000 smoking in reply to Bud, 07-31-2000 05:14:00
If it's white smoke, it's probably suffering from low compression. If so, it could be hard starting in the winter time.
Bud
08-01-2000 05:41:27
 Re: Re: 4 cyl 4000 smoking in reply to Bern, 07-31-2000 18:21:33
The smoke is black. They just put a rebuilt injector pump on it.Maybe its not adjusted right?
Bern
08-01-2000 07:39:55
 Re: Re: Re: 4 cyl 4000 smoking in reply to Bud, 08-01-2000 05:41:27
Could possibly be timing related. However, black smoke is usually attributed to a plugged air cleaner and/or too much fuel combined with an overloaded engine.
raytasch
07-31-2000 15:20:14
Would want to know what color smoke. My 4000 diesel lets out a little black smoke when you start it but clears up after about 30 seconds. When you really get it against the governor it will blow a little black smoke. Does not use any oil and it stays reasonably clean for a long time. First thing I would check is the air cleaner. fwiw, ray
