Order Ford 5000 Parts Online
Ford 5000
Bobby
08-02-2000 08:07:49
After tractor gets hot(in about 30 min) 3 point lift wont pick up disc.Also independent P.T.O is slow to engage.Some times it takes about 5 min.It all works OK when the tractor is first started up.I have checked the fluid level it is ok.Thanks for Help Bobby
RickB.
08-02-2000 17:24:04
 Re: Ford 5000 in reply to Bobby, 08-02-2000 08:07:49
Could be several things, but sounds most like a worn hydraulic pump.
bobby
08-03-2000 11:00:19
 Re: Re: Ford 5000 in reply to RickB., 08-02-2000 17:24:04
do you thnik adding something like Tran-X to the fluid would help.
Bobby
RickB.
08-03-2000 14:26:35
 Re: Re: Re: Ford 5000 in reply to bobby, 08-03-2000 11:00:19
It sure would help the folks selling Tran-X.
