Order Ford NAA Parts Online
Golden jubilee hydraulic pump prime procedures
B.Q.
08-03-2000 19:23:17
I recently changed the hydraulic fluid to discover problems with my lifting mechanism. In other words, it don't work no more! I think I lost the prime to the pump but uncertain how to reprime. The piston type pump has two ports on the pump head. Of course, the one nearest the engine block has to be the one the allen head socket is wallowed out! Therefore, I have tried to bleed with the port on the outside and easy to remove the plug. I equipped the port with a pipe to take the fluid back to the resevoir with the engine running to expell the air. In spite of repeated trials I remain unsucessful. Those familar with the pump prime act, allow me to ask questions. 1.) are the two ports the same when purging air from the pump? 2.) is there another method of priming I am unaware?
Chris
08-03-2000 20:55:39
 Re: golden jubilee hydraulic pump prime procedures in reply to B.Q., 08-03-2000 19:23:17
I had the same problem. My local NH dealer told me to pull the dip stick out(where you check the hydro fluid)and take an air hose and shoot air into this port. Make sure the tractor is running and you raise and lower the arms. You might want to put a small load on it. I had to do it several times on my 860 before it caught the prime. You might need to hold a rag or something around it so air cant escape. Be careful not to put to much pressure in it. It is possible to blow internal seals.
Hope this helps,
Chris
