Order Ford 4000 Parts Online
4000 Ford Parts Manual/ Hydraulic leak Repair
DMunoz
08-08-2000 21:59:34
I am trying to determine what year model that I have so that I can purchase the proper repair manual. Numbers found on block as follows: R.H. side...D101 1K15B C316185 L.H. side...1H19B C7018. I have a hydraulic leak at the tube between the lift speed control knob mtg. plate and the plate below it. I am sure that the o-rings need to be replaced on the tube but am not sure how to go about doing it without chancing dropping something in the transfer case as I am not familiar with the assembly.
wayne knight
08-28-2002 13:39:13
 Re: 4000 Ford Parts Manual/ Hydraulic leak Repair in reply to DMunoz, 08-08-2000 21:59:34
I have a leak in my ford 4000 power steering system. I loose a full canister within minutes and don't see where it is going to? I presume it is flowing into the base through the pump. Is it possible to rebuild / reseal (o-rings) yourself? Thanks Wayne
wayne knight
08-28-2002 13:48:55
 Re: Re: 4000 Ford Parts Manual/ Hydraulic leak Repair in reply to wayne knight, 08-28-2002 13:39:13
can I rebuild / o-ring a hydraulic pump myself for a power steering pump on a ford 4000 ?
RickB.
08-09-2000 14:22:39
The date code 1H19B places your 4000 as a 1971 (Aug) build. The correct repair manual from New Holland (.com/na) will cover 2,3,4&5000 tractors from 1965 to about 1972 or so. The repair you are facing will require the removal of the lift cover and the flow control valve assembly.
