Hydralics
bob mcgee
08-09-2000 16:48:03
ive got a 1954 naa i changed all gaskets,o-rings and new 90 w oil (this includes vane pump). is there something like marvel mystery oil etc. that i can put in oil? it works fine until its hot.
Gregg Metzger
11-16-2000 02:52:26
 Re: hydralics in reply to bob mcgee, 08-09-2000 16:48:03
I'm very new at this stuff! I have a 1952 8N Ford tractor with hydralic problems. First of all, my
hydralic draw arms only raise when my PTO is on. Is this normal? Lastly, my draw arms will not sustain any raised load for a given period of time. You can actually watch the arms lower by themselves. On the same note, the arms will not raise an implement to any considerable height. The hydralic oil is correct type and capacity. Do I have seal problems?
William Ireland
08-12-2000 16:07:51
For the life of me I can't understand the 90 W oil in your naa l954.My 1953 Naa Jubilee requires regular hydraulic oil, ford specs.The 8 N requires the 80=90 W oil as used in trans and rear as well as hydraulics but you have a different type of pump in the different tractors.Check the specs for your hydraulic system.
bob mcgee
08-13-2000 02:46:46
 Re: Re: hydralics in reply to William Ireland, 08-12-2000 16:07:51
i tried the ford 134 it wouldnt work at all. i was told by a old timer. that its to hot in texas try 90 wt (i think i need a new pump) thanks
William Ireland
08-13-2000 10:22:29
 Re: Re: Re: hydralics in reply to bob mcgee, 08-13-2000 02:46:46
e mail me and I will wrtie the poblems and check points I had to use to correct mine
William Ireland
08-13-2000 10:22:17
