Factory Sherman??
Austin Gibbons
08-10-2000 19:25:20
Was a Sherman high/low's a factory option on 641's?? That's what I was told by a seller and I just thought I better check it out. Also, can anyone tell me about the Ford 701 loader and what kind of a match it is for the 641??
Thanks
AJG
craig
05-06-2004 10:15:50
 Re: Factory Sherman?? in reply to Austin Gibbons, 08-10-2000 19:25:20
how hard is to install a sherman hi lo transmition
on a ford 640 and what has to be changed on tractor.
Jim.UT
08-11-2000 12:55:01
Horseman is right. Here's the link to the site he referenced:
horseman
08-11-2000 18:24:13
 Re: Re: Factory Sherman?? in reply to Jim.UT, 08-11-2000 12:55:01
Thanks Jim! I knew you would put that link in there . Me and computers just don't get along. I think they need gears and grease then I might be able to figure them out! WRP
Horseman
08-11-2000 08:18:58
According to the antique tractor resource page the sherman combo. trans. was dealer installed until 1957. After that it could be factory installed. What year is your machine? I have an 841D with the sherman. Acording to a retired mech. from the local ford dealership mine used to be an SOS then ford sent up a bunch of 4spd conversions for the dealers to change out. You can tell on mine because it has the hole in the dash for were the pto pull lever was for the SOS. mine is a"61" good luck they are good machines WRP
